FAULT CODE 12
FAULT CODE 12
This fault code has happened on my bongo twice spaced about a week apart. both times it has occurred it has been raining. could this have any bearing on why the hold light is flashing this fault. I've heard it's the Thottle position sensor. is it serious, is it expensive and what does it do. can anyone help :
Where do you get the fault codes? I occasionally get a hold light flashing and no speedo reading, which I have been told is a speed sensor fault, but I have no idea where the fault code is shown.
Switching the ignition off then re-starting usually cures it, but I'm sure one day it won't and I will have to investigate further. At the moment though, it only happens once in a blue moon, so I'll worry about it when I have to.
throttle position sensor not available at the moment,being told have to buy complete pump at £1400 but working on alternatives!!!moonshine ,if your speedo is converted using a chip?bin it and fit a speedo face as this sounds like a familiar fault that i have now rectified in this way on numerous occasions
Dawlish Import Centre
http://users.autoexposure.co.uk/dawlish ... /index.htm
fault code 12
hi i have same problem but not intermitent try changing gear box oil and clean filter we are going to try that today, i have a second hand fuel pump and gear box coming tuesday will then swap parts over to find the fault if its not the throttle sensor will stick the gearbox in will get there in the end ?
Throttle position sensors
finally found somewhere that can get them direct from Japan. Auto link in Hants 01489 877770. reckons 4-6 weeks delivery time. price £100 inc Vat
fault code 12
hi have cured fault code 12 throtle sensor causing open circuit the man to talk to is simon at autotonic petersfield hampshire tel 01730893893 hope this helps ?
