Sliding Door Not Shutting Fully
richmab
Post by richmab » Wed Jan 11, 2017 8:31 pm
The sliding door on my Bongo does close properly. It used to pull right in. However, now it barely moves inwards at all. I can hear the motor noise and it still lock and does not leak. It just looks odd as it is not fully closed.
Any ideas please?
Thanks,
Rich.
Re: Sliding Door Not Shutting Fully
Post by Bob » Wed Jan 11, 2017 8:41 pm
Warm welcome to BF. :D
Are you pulling it forwards firmly enough?
If it doesn't come far enough forward manualy the motor runs but it won't shut.
Hope that helps, and others will have some ideas. :)
Post by Northern Bongolow » Wed Jan 11, 2017 10:40 pm
first i would clean the little silver contacts on the door pillar and on the door, these work the motor/mechanism, if the door contacts are touching initially and the door is part closing, then as the door tries to fully shut the contact is lost it may not pull the door fully closed. you could try a gentle help by leaning on it if its just the back end is sticking out a bit.
or.
if someone has thrown open the door you can strain the roller carriers, so the carrier/s are bent out slightly, it may need adjusting, this is done by slackening the mounting bolts on each of the 3 rollers carriers.BUT be carefull it is quite difficult to get the door sitting square and properly fitted and may need several attempts and several people to hold the door weight while you loosen/tighten the bolts.
or.
try oiling the the door mounts, they have a pivot point like a hinge with rollers fitted to one end.
Post by teenmal » Fri Jan 13, 2017 12:38 pm
If the door locks with the soft close ,and the door does not infill all round, I would check the roller/carrier mechanisms.
richmab
Post by richmab » Mon Jan 16, 2017 8:05 pm
Thank you for the suggestions. I will give them a go at the weekend
Jillygumbo
Post by Jillygumbo » Tue Jan 17, 2017 1:37 pm
I had a similar issue when I picked up my bongo from JAL. It was adjusted by Dave in Worcester, but not fixed. Allan had a go too. It's better than it was, but it's still not completely fixed.
I've learned to live with it!
Jillygumbo, Marvin & Lady
