Roof AFT problems
wells0111
Roof AFT problems
Post by wells0111 » Tue Nov 29, 2016 2:28 pm
Apologies if this has been covered before.
1997 AFT diesel auto.
When I try to raise the AFT absolutely nothing happens.
I have checked the handbrake switch which is fine. I have checked the 30amp fuse no. 12 its fine.
There is no bleep and no voltage drop across the battery.
Any ideas?
Many thanks
Re: Roof AFT problems
Post by mikeonb4c » Tue Nov 29, 2016 4:10 pm
Where are you based? I had similar woes ans was forever grateful i could take it to Adrian at Japandirect in Bury, who was able to sort it as he has proper hoisting gear.
callum
Post by callum » Tue Nov 29, 2016 5:35 pm
Try taking th switch apart. I did it to mine a couple of weeks ago as i had a similar issue, it was gunky, same as blind switches. Cleaned out with contact cleaner and it works a treat.
Post by g8dhe » Tue Nov 29, 2016 5:39 pm
Does the Handbrake light come on on the dashboard? If not then that is the cause of the problem, after that suspect the roof up/down switch.
Dr Fingers
Post by Dr Fingers » Fri Dec 02, 2016 7:05 pm
Roof up/down switch went on ours. Easy fix!
Derek
wells0111
Post by wells0111 » Fri Dec 02, 2016 7:07 pm
Thanks for the replies. Roof switch, 1st job tomorrow.
Post by mikeonb4c » Fri Dec 02, 2016 9:04 pm
Dr Fingers wrote:Roof up/down switch went on ours. Easy fix!
Derek
How did you fix it Derek - mine's going a bit dicky in damp/cold weather generally
wells0111
Success.
Post by wells0111 » Sat Dec 03, 2016 4:24 pm
Success. Removed switch and disassembled. Contacts were dirty and smothered in grease.
Everything cleaned, reassembled and now working..
Many thanks for your help.
Re: Success.
Post by mikeonb4c » Sat Dec 03, 2016 6:00 pm
wells0111 wrote:Success. Removed switch and disassembled. Contacts were dirty and smothered in grease.
Excellent. You've done me a favour as now i can service mine! Does the switch prise out of the headlining easily? Is it straightforward to take it apart?
wells0111
Post by wells0111 » Sat Dec 03, 2016 6:56 pm
Yes the switch comes out easily. If you press it either way you can we the tab at the other end which holds it in. I pulled the tab back with a small screwdriver and pulled out easily.
Post by mikeonb4c » Sat Dec 03, 2016 8:30 pm
wells0111 wrote:Yes the switch comes out easily. If you press it either way you can we the tab at the other end which holds it in. I pulled the tab back with a small screwdriver and pulled out easily.
Cheers for that - its on the long long to-do list :roll: :lol:
callum
Post by callum » Sun Dec 04, 2016 2:23 am
Mike,have you done your blind switches? It is exactly the same inside, a lovely thing to do as it is 10 mins to do and fixes a problem, not often the case with other jobs!
Post by mikeonb4c » Sun Dec 04, 2016 1:10 pm
callum wrote:Mike,have you done your blind switches? It is exactly the same inside, a lovely thing to do as it is 10 mins to do and fixes a problem, not often the case with other jobs!
Yes i did them (the dash master switches) several years ago BUT just swapped existing for replacements i'd bought so never actually tried opening up and cleaning the old ones. Is it easy to do? One thing i'd like to do is fix the bulb in one of those switches though if i can get all four working there ought to be two with working bulbs!
Lots of fettling to keep me busy in retirement ;-)
I use my blinds now almost every time i park up, just to keep everything exercised. Not so practical with the roof mind you! :lol:
Dr Fingers
Post by Dr Fingers » Tue Dec 06, 2016 6:17 pm
Derek
swapped with switch from a donor vehicle!
Derek
Post by mikeonb4c » Tue Dec 06, 2016 6:34 pm
Doh - should have guessed!
