bearings
davepickering
bearings
Post by davepickering » Sat Nov 05, 2016 6:20 pm
Hi, new to the site :D can anyone give me info on the sizes I need for the rear half shaft bearings on my 1995 2.5D 4wd
Bongolia
Re: bearings
Post by Bongolia » Sat Nov 05, 2016 6:33 pm
Pretty critical and manufactures do alter them between years so if you are looking to source them from bearing supplier, and it is a lot cheaper that way, then pull the shafts and you will see a number on the bearing,quote that.
davepickering
Re: bearings
Post by davepickering » Sat Nov 05, 2016 6:54 pm
thanks Bongolia for the info will draw shaft an have a look :)
Re: bearings
Post by teenmal » Sat Nov 05, 2016 8:39 pm
The part number is S10H26151 for all variants . Your bearing supplier should be able to do a cross reference.
davepickering
Re: bearings
Post by davepickering » Sat Nov 05, 2016 10:22 pm
thanks :) teenmal will try this No on monday
