bearings
- Bongonaut
bearings
Hi, new to the site
can anyone give me info on the sizes I need for the rear half shaft bearings on my 1995 2.5D 4wd
Re: bearings
Pretty critical and manufactures do alter them between years so if you are looking to source them from bearing supplier, and it is a lot cheaper that way, then pull the shafts and you will see a number on the bearing,quote that.
- Bongonaut
Re: bearings
thanks Bongolia for the info will draw shaft an have a look
Re: bearings
The part number is S10H26151 for all variants . Your bearing supplier should be able to do a cross reference.
- Bongonaut
Re: bearings
thanks
teenmal will try this No on monday
