What Screws to use on Bulkhead
cuchillo
Post by cuchillo » Fri Oct 28, 2016 5:53 pm
Hello,
I wish to mount a bus bar onto the bulkhead under the bonnet. What screws can/should I use? I assume that its OK as the VSR has been screwed onto the bulkhead already.
Many thanks
Cuch
wonkanoby
Re: What Screws to use on Bulkhead
Post by wonkanoby » Fri Oct 28, 2016 6:50 pm
any self tapper,trick is to be sure you dont drill or screw into any thing behind it
Post by Bob » Fri Oct 28, 2016 9:32 pm
Agree, likely No 6 or 8, pan head, slotted or pozi, and long enough that 3 threads go through the bulkhead, but as said, not into anything behind the hole.
Post by haydn callow » Sat Oct 29, 2016 10:24 am
Use Stainless if you have any.
