Split charge relay
Bikerp
Split charge relay
Post by Bikerp » Mon Aug 29, 2016 9:05 pm
Hi all,I have just fitted a new split charge relay and am wondering if I have wired it correctly?With the engine off the SB has 12.6 volts and the LB 12.5 volts.When I switch the engine on the SB drops to 12volts and the LB stays at around 12.5.Is this normal? :?
scanner
Re: Split charge relay
Post by scanner » Mon Aug 29, 2016 9:29 pm
With the engine running the starter battery should be at about 14 volts and when the relay closes the leisure battery should be at about the same voltage because it is then linked direct to the starter battery.
With the engine off (and after leaving it a couple of hours for voltages to stabilise) both batteries should read somewhere between a minimum of 12.5v and a maximum possibly as high as 13.0v
Post by g8dhe » Mon Aug 29, 2016 9:36 pm
When you say switch the engine on you do mean actually start it? Once the engine is running then the alternator charges the batteries.
Bikerp
Post by Bikerp » Mon Aug 29, 2016 9:40 pm
Hi,yes when I start the engine the voltage drops to 12volts on the starter battery?
scanner
Post by scanner » Mon Aug 29, 2016 9:46 pm
It should be as I said, for the reason Geoff said.
Bikerp
Post by Bikerp » Mon Aug 29, 2016 9:51 pm
So is the alternator not charging?Is it wired incorrectly?
Post by g8dhe » Mon Aug 29, 2016 10:04 pm
Normally if the Alternator is faulty and not charging then the "CHARGE" light will stay on on the dashboard, it will come on with the ignition and then go out when the engine is running and spinning the alternator. If its a diesel then the Sediment lamp will also be lit.
As to is it wired incorrectly I've no idea you will have to tell us what kit and how you wired it! Photo's help a lot!
