mystery switches
tompusey
mystery switches
Post by tompusey » Tue Aug 09, 2016 9:46 am
there are 2 switches on the drivers side below the steering wheel that have no label, one is just below the steering wheel, and the other (above the fuses) has a blue LED that lights up when its switched, but I have no idea what either of them does? Anyone have any clue what these do? (photo link below)
https://goo.gl/photos/rzthhFTLd833bAck8
Thanks in advance
Tom
Re: mystery switches
Post by Bob » Tue Aug 09, 2016 9:52 am
Welcome aboard.
One of them is very likely the rear fog light.
Switch on headlights then try it. :wink:
They're not required in Japan but must be fitted on import for MOT. 8)
Jillygumbo
Post by Jillygumbo » Tue Aug 09, 2016 12:48 pm
Agree the one on the right is likely to be the rear fog light, which won't work until the lights are switched on.
The other one may be connected to a low coolant alarm or the immobiliser. Does it come on the make a noise when you turn the ignition on? If so, it's the coolant alarm telling you it's working! Or if it just flashes when you turn the ignition on, it could be the immobiliser?
My electric guy added a switch like the fog light one so I could turn off the aftermarked CD/radio rather than leave it on standby, but he wired it into the retracting wing mirrors! So I found out ...
Jillygumbo, Marvin & Lady
tompusey
Post by tompusey » Tue Aug 09, 2016 3:47 pm
I'll check those out later. Thanks guys!
tompusey
Post by tompusey » Tue Aug 09, 2016 9:07 pm
right hand one is the rear fog light!
Post by Bob » Tue Aug 09, 2016 9:21 pm
Bingo. :D
