VSR and fusebox on split charging loom
timhowes
Post by timhowes » Sun Jul 17, 2016 5:01 pm
Hi folks
First-time poster so apologies for probably breaking all the rules. I did have a search for answers to this Q first, mind.
I've bought a Raynes Automotive split charging loom with VSR. As I'm a Bongo newbie I thought it might be reasonable to ask this fairly simple question:
Where is a good place to attach the plastic box housing the VSR? And same question about the little fusebox? No inappropriate suggestions of where to stick them etc please.
A pic of the device in question is here: http://www.rayneautomotive.co.uk/mazda- ... y-kit.html
Would it be a bit rubbish to attach them using double-sided adhesive pads to some unoccupied bodywork under the bonnet? Don't really want to drill holes in metal just for this.
Thanks in anticipation
Tim
cmm303
Re: VSR and fusebox on split charging loom
Post by cmm303 » Sun Jul 17, 2016 7:26 pm
A very warm welcome to the forum.
I would not personally trust adhesive pads. Mine is attached in place of the blanking plate in the bulkhead for the manual clutch, because it was designed to do so. However it may be easy to make a similar bracket or plate up to mount your VSR and fuse panel. I'm sure members with first hand experience will be along.
Chris with BertieB
Post by g8dhe » Sun Jul 17, 2016 7:27 pm
Double sided tape isn't likely to last that long what with heat and water, quite often people will use self-tappers into the cabin air ducting, but often if you look closely you will find enough existing screws to mount the brackets on or there are several unused plastic stubs which can have bolts screwed in to them..
cmm303
Post by cmm303 » Sun Jul 17, 2016 7:39 pm
g8dhe wrote:Double sided tape isn't likely to last that long what with heat and water, quite often people will use self-tappers into the cabin air ducting, but often if you look closely you will find enough existing screws to mount the brackets on or there are several unused plastic stubs which can have bolts screwed in to them..
interesting Geoff. I changed my mind about posting a description of a friend's professionally converted Bongo with the VSR screwed in across the join in the ducting, such that the screws were obscured by the LB. 20 mins to get to the rad, instead of 2. Naughty converter!
Chris with BertieB
timhowes
Post by timhowes » Sun Jul 17, 2016 7:47 pm
Thanks folks. My VSR is just too small to screw into the holes under that clutch blanking plate in the bulkhead. But perhaps I could attach the boxes to said blanking plate and re-insert that. Will get in the shed and work something out.
Not sure about tapping screws into the ducting, it obviously crossed my mind but I have to say I didn't fancy it,
Keep the ideas coming please!
Post by Northern Bongolow » Sun Jul 17, 2016 9:23 pm
it says in the sales blurb that this kit is made to measure for the bongo, can you not lay it out as the fitting instructions say, then work backwards to a vsr mounting point, it may be fairly obvious.
file:///C:/Users/User/Downloads/Bongo%20VSR%20diagram.pdf
timhowes
Post by timhowes » Sun Jul 17, 2016 10:07 pm
Thanks Northern B, I inspected all of the documentation on their webby first but no suggestion of where to mount the VSR.
It's a minor problem, just wanted to know if others had ingenious solutions they were keen to share!
