Roof light
B12ROCK
Roof light
Post by B12ROCK » Tue May 31, 2016 6:08 pm
Hi, the light in my pop up roof isn't working, I've tried a new bulb but no luck. Everything else is working OK so the fuse should be OK. I've lent my multimeter to a mate so can't check for voltage, is there something I'm missing is there a microswitch to turn the light off with the roof down? Thanks in advance.
callum
Re: Roof light
Post by callum » Tue May 31, 2016 7:48 pm
Hi, can you confirm that you are trying it with the roof up? It only works with the roof raised. I only recently discoved this!
Re: Roof light
Post by g8dhe » Tue May 31, 2016 8:43 pm
Yes the switch has the earth removed when the lowered limit switches operate, needs to be open a few inches to allow the light to come on!
B12ROCK
Re: Roof light
Post by B12ROCK » Wed Jun 01, 2016 12:09 pm
Yes I had the roof up, do we know where the earth is switched that sounds like the probable fault. Cheers
mikeWalsall
Re: Roof light
Post by mikeWalsall » Wed Jun 01, 2016 12:45 pm
With most interior lights .. the light itself is wired live ..
The switch completes the circuit via the earth ..
ie: if it's the same as a door .. usually the wired plunger / metal plate / retaining screw ..
Re: Roof light
Post by g8dhe » Wed Jun 01, 2016 1:33 pm
Yes its done by one of the limit switches as the roof comes down;
Its M2-06 which is the offside front limit switch, it takes the earth off the lamp and sends it to the computer to tell it to stop the motors along with the switch on the nearside.
