Roof bar bolts
Bvan
Roof bar bolts
Post by Bvan » Fri May 13, 2016 1:31 pm
Hi all! Can anyone tell me what size the bolts are for fitting the roof bars to the aft roof, please?
al & chris
Re: Roof bar bolts
Post by al & chris » Fri May 13, 2016 4:50 pm
From memory I think they are M8 sure someone else will confirm.
Re: Roof bar bolts
Post by g8dhe » Fri May 13, 2016 5:34 pm
There is another reference to M8 here as well http://igmaynard.co.uk/bongo/forum/view ... 07#p622007
the1andonly
Re: Roof bar bolts
Post by the1andonly » Fri May 13, 2016 6:28 pm
yes M8
Re: Roof bar bolts
Post by Simon Jones » Fri May 13, 2016 10:02 pm
M8 x 1.5 is the correct pitch for the thread.
the1andonly
Re: Roof bar bolts
Post by the1andonly » Fri May 13, 2016 10:13 pm
and don't forget the length required, please don't try and extract the 'captive' nut.
the not very pretty washers adjust the length of contact without cutting the bolt. (corrosion)
ps the installation was a standard gutter clamp system with the clamp removed and an hole drilled for the bolt
(thanks to an old post for the suggestion, kirsty I think)
Bvan
Re: Roof bar bolts
Post by Bvan » Sat May 28, 2016 7:29 pm
Thanks everyone M8 x 1.5 it is :-)
