Replacement O/S wing mirror ????
martinc
Post by martinc » Fri May 06, 2016 4:02 pm
Hi All ,
Well while lately ive been taking out the bongo to keep it in good running order so its ready for the up and coming trips this year . However some kind soul decieded to get so close to have a look at the bongo that they caught my wing mirror and so my glass was smashed out =D> =D> =D>
Luckily the actual wing mirror is still intact , but missing the glass but im not sure if i could just replace it with a sticky backed glass or does it need some sort of bracket to attach the glass to the wing mirror .???
hopefully you can help .
cheers
Martin
Re: Replacement O/S wing mirror ????
Post by g8dhe » Fri May 06, 2016 4:08 pm
You need the plastic clip that fits onto the four corners ideally, was it not on the ground with the smashed mirror ?
martinc
Post by martinc » Fri May 06, 2016 4:22 pm
hi G8dhe ,
thanks for the reply , i didnt see anything but i might go check again .
can you get replacement clips ?
cheers
Martin
Post by teenmal » Fri May 06, 2016 5:41 pm
Looking at your mirror I would say (not 100%) that you need the backing plate that the glass is stuck/clipped onto then it Snaps into the electric mirror adjusting pivots . As I say not 100% sure on these vehicles but this is the case in a lot of vehicles.
Post by g8dhe » Fri May 06, 2016 6:42 pm
I've not heard of spare ones, but never needed to find one, if anyone could supply it will be Bongo Spares http://www.bongospares.co.uk/
or any of the normal suppliers not seen them listed in the shop either.
martinc
Post by martinc » Fri May 06, 2016 7:19 pm
well ive been to have a look again but no luck , so it looks like im going to have to source a new one !
Martin
Post by teenmal » Sat May 07, 2016 9:03 am
The Bongo Fury shop sells the glass for £36.00,for that price I would imagine that it will be the full Monty, glass and backing plate? you could contact the shop to find out.
martinc
Post by martinc » Sat May 07, 2016 11:07 pm
Thanks teenmal I was thinking of looking in the bongo shop .
Do we as members get any discount ?
Martin
Post by Simon Jones » Sun May 08, 2016 9:29 am
As per the latest email update from Mission Control, you get 12.5% discount as a paid up member when entering the code at the checkout stage.
martinc
Post by martinc » Sun May 08, 2016 10:08 pm
thanks for the advice on the discount as i was unaware of this , however the item is still expensive for what it is ?
any other suggestions ?
cheers
Martin
Post by teenmal » Mon May 09, 2016 6:48 am
Ebay
martinc
Post by martinc » Mon May 09, 2016 10:32 pm
teenmal wrote:Ebay
evening ,
ive looked on ebay , however nobody wants to sell just the backing plate and mirror !
looks like i will haveto bite the bullet and just pay £35 for them via the bongo shop .
also how hard is the actual wing mirror to remove /
cheers
Martin
Post by g8dhe » Mon May 09, 2016 10:47 pm
Do you need to remove the mount itself ? The new mirror if it comes with clip attached just pushes on.
martinc
Post by martinc » Tue May 10, 2016 1:08 am
g8dhe wrote:Do you need to remove the mount itself ? The new mirror if it comes with clip attached just pushes on.
No i dont need to remove the whole assembly , however i was toying with the idea of making the wing mirrors colour coded ?
Martin
Post by mikeonb4c » Tue May 10, 2016 8:11 am
Perhaps Ian at the Bongo Shop could advise if theirs comes with clips on (price suggests it might) as i'm not sure all do.
