Replacing the Drivers door loom
I've put together a pictorial guide for replacing the loom here, click the image below for the full works;
Re: Replacing the Drivers door loom
Nice job Geoff. Get that in a factsheet pronto!
Nice job Geoff,well done.
Brian
Brian
Nice one Geoff, thanks.
Defo one for a fact sheet or sticky
Chris with BertieB
There is already a Factsheet that Helen put together, which has a VERY handy tip which I repeat in the pictures version - pull the connectors out of the A Pillar, I had spent ages trying to access the connectors from inside until seeing Helen's idea!
- Jillygumbo
Excellent, thanks Geoff.
Jillygumbo, Marvin & Lady
Well done Heleng8dhe wrote:There is already a Factsheet that Helen put together, which has a VERY handy tip which I repeat in the pictures version - pull the connectors out of the A Pillar, I had spent ages trying to access the connectors from inside until seeing Helen's idea!
- mikeWalsall
Brilliant .. like I say .. a picture is worth a thousand words ..!!
Where can you get the loom from? My central locking isn't working and I'm thinking this is likely a fix for it.
I had mine replaced only to discover later the problem was a dodgy connector in tbe control box behind tbe passenger glove box. Worth checking that before forking out (mine is temporarily sorted by not pushing tbe faulty connector fully home!)
