Air bag warning light
BeardyBongolian
Post by BeardyBongolian » Fri Feb 19, 2016 1:22 am
I was wondering if anyone had any ideas about why my air bag warning light flashes regularly, but then stops for a couple of days then starts again?!? Is it likely there is a fault in the system and best to get it checked out at a garage, or could it be a lose wire that I could fix? Have only owned my 2000 reg Bongo for 4 months, so still a novice! Any suggestions and help would be much appreciated!
Re: Air bag warning light
Post by Bob » Fri Feb 19, 2016 1:43 am
Can't help with the light I'm afraid, but a warm welcome to the Forum.
Someone will know. :)
Post by Simon Jones » Fri Feb 19, 2016 1:12 pm
Welcome to the forum :). With airbag warning lights being an MOT failure it's an idea to get the problem fixed at earliest opportunity. A quick search for 'airbag AND light' returns a lot of info from when other owners have experienced the same issue: http://www.igmaynard.co.uk/bongo/forum/ ... mit=Search
BeardyBongolian
Post by BeardyBongolian » Sat Feb 20, 2016 2:07 pm
Thanks for the welcomes and link- I'll give it a look over and see if I can work out where the problem is! It has stopped flashing at the mo! :D
Post by Northern Bongolow » Sat Feb 20, 2016 4:03 pm
this may give you an insight into the clock spring and how it works.
http://www.igmaynard.co.uk/bongo/forum/ ... 29#p651229
stuc
Post by stuc » Sat Feb 20, 2016 10:51 pm
My airbag light was flashing for ages until I disconnected the battery, left for 5 min, removed drivers airbag, removed passenger airbag , reconnected them both and refitted them then re connected battery and that sorted it. Never flashed since.
Worth a try for half an hours work.
Stu
