Full Beam
Helen44
Full Beam
Post by Helen44 » Fri Dec 18, 2015 7:13 pm
When I turned my headlights on today, the full beam dashboard indicator light came on and I couldn't get the dashboard indicator light to go off regardless of what setting I turned it to. However, the full beams themselves weren't coming on at all. The side lights came on but I couldn't seem to switch to full beams.
Any suggestions?
mikeWalsall
Re: Full Beam
Post by mikeWalsall » Fri Dec 18, 2015 8:01 pm
Maybe a faulty headlight relay .. it is on the N/S inner wing by the plastic water reservoir .. or leisure battery if you have one ..
Sometimes a sharp tap temporally may release the internal contacts ..
Helen44
Re: Full Beam
Post by Helen44 » Fri Dec 18, 2015 8:47 pm
Thanks,
We will give this a go tomorrow
mikeWalsall
Re: Full Beam
Post by mikeWalsall » Fri Dec 18, 2015 9:16 pm
Also check the windscreen gutter outlet is clear .. sometimes water over flows into some of the electrics
Helen44
Re: Full Beam
Post by Helen44 » Sat Dec 19, 2015 4:24 pm
Hi Mike,
I was just rereading this and wondering if maybe I misunderstood your post last night. Do you mean that a sharp tap could have caused the problem? And if so, how do you suggest it could be remedied?
Thanks,
mikeWalsall
Re: Full Beam
Post by mikeWalsall » Sat Dec 19, 2015 4:31 pm
The relay is a a simple heavy duty switch .. works a bit like a Ding ... Dong .. door bell ..
Although covered in 'water proof' rubber .. given the position of the relay boxes they can get water / moister inside that stops them working efficiently .. even overloaded so the contacts 'weld' together ..
A sharp tap may get them working .. if only temporary ..
Re: Full Beam
Post by g8dhe » Sat Dec 19, 2015 4:43 pm
If the Beam dashboard light is coming on then the problem will be with the head lamp or connector, quite often the lamp connector corrodes then overheats.
If the dashboard light then doesn't go off, then that points towards the relay, so you may have a double fault, blown bulb or bad connector and a relay welded in the on position.
mikeWalsall
Re: Full Beam
Post by mikeWalsall » Sat Dec 19, 2015 6:13 pm
As Geoff says .. the bub holders on the back of the headlights can cause problems .. a simple DIY fix is to fit ceramic bulb holders ..(the Shogun and many other motors use the same H4 Halogen bulbs) ..
http://www.ebay.co.uk/itm/2x-MITSUBISHI ... xyNwNSKFff
