Air lift 1000
redz79
Air lift 1000
Post by redz79 » Wed Dec 09, 2015 9:04 pm
I finaly got round to fitting an air lift 1000 kit to my Bongo, what psi would be a good starting point ?, its a V6 with lpg and a towbar so theres plenty of weight on the rear axle,i put 10 psi in each side to keep he bags shape.
rgds Ian
Re: Air lift 1000
Post by g8dhe » Wed Dec 09, 2015 9:23 pm
With a full side conversion and R&R bed, with a rear Thule box on the Towbar fully loaded, we found just 20PSI removed all the previous banging around as it grounded out, I think I started at about 30-40 and slowly dropped it down between trips and at 15PSI the banging came back so then put it back to 20PSI and have left it there ever since.
weebrian
Re: Air lift 1000
Post by weebrian » Thu Dec 10, 2015 9:23 am
I found that although 20/25psi gets rid of any bottoming out, 40/50psi gives a nice solid rear end and eliminates any wallowing on faster bends and corners. Makes for a harsher ride on rough surfaces but worth the trade off as I don't often drive on poorly surfaced roads.
redz79
Re: Air lift 1000
Post by redz79 » Thu Dec 10, 2015 8:54 pm
thanks for the replies, i'll go with 30psi to start with, the camping stuff is kept in the van in the summer, then we notice the bottoming out over speed bumps etc, I've fitted the bags independently , at some point in the future i'd like a kitchen pod on the drivers side rear corner, so i'll need a few psi more on that side for the extra weight.do you have yours linked ?
rgds
Re: Air lift 1000
Post by g8dhe » Fri Dec 11, 2015 12:31 am
I've kept ours independent, but always at the same pressure.
