Faded headlamps - a solution
TerryG
Post by TerryG » Thu Dec 03, 2015 12:42 pm
After trying various things pre-mot (they were an advisory last time round) I found that Autosol chrome polish does an excellent job, for the minimum of effort.
'Enjoy every sandwich'
Re: Faded headlamps - a solution
Post by Bob » Thu Dec 03, 2015 1:53 pm
Good shout, thanks.
Mine need doing. :roll:
Post by Bob » Thu Dec 03, 2015 4:08 pm
Well, it was the Autoglym chrome polish in the garage, but what a difference, should have done this ages ago.
Bongoplod
Post by Bongoplod » Fri Dec 04, 2015 12:03 am
Bob wrote:Well, it was the Autoglym chrome polish in the garage, but what a difference, should have done this ages ago.
Did you give it a hand job Bob :shock: or use a buffer ??
Brian
Post by Bob » Fri Dec 04, 2015 12:04 am
Just elbow grease. 8)
simmonsmob
Post by simmonsmob » Fri Dec 04, 2015 2:41 am
I got the same result using Brasso. 5 mins rubbing then wiped off with a baby wipe, job done.
cmm303
Post by cmm303 » Fri Dec 04, 2015 7:47 am
Follow up with a UV resistant car polish to slow down the fogging up.
Chris with BertieB
Post by Bob » Fri Dec 04, 2015 9:55 am
Good tip. :D
Diplomat
Post by Diplomat » Fri Dec 04, 2015 11:30 am
cmm303 wrote:Follow up with a UV resistant car polish to slow down the fogging up.
Would factor 15 sun cream do for the follow up?
Frank
They flew, I took up naturism
cmm303
Post by cmm303 » Fri Dec 04, 2015 1:05 pm
Frank
So long as you dont take it swimming
Chris with BertieB
Post by rita » Fri Dec 04, 2015 1:59 pm
Crystal Disc repair fluid is the daddy for the UV problem.
windywatson
Post by windywatson » Fri Dec 04, 2015 2:49 pm
The "Range" DIY super store do a good headlight refurbishment kit amounts their car parts. That comes complete with a final application of UV/Protective coating. I've used it with good results.
Windy-Watson
2001 V6 Tin Top
mickc
Post by mickc » Fri Dec 04, 2015 9:55 pm
I used 2000 grit wet and dry with a little washing up liquid in the water, brought them up like new.
Post by Bob » Fri Dec 04, 2015 10:48 pm
Thanks. :D
TerryG
Post by TerryG » Sat Dec 05, 2015 2:55 pm
Ok, here's another one I've just thought of: wood ash from the log burner. We use it on a damp sponge to clean the glazed doors of the woodstove, and it works a treat. Didn't think of it until after using the Autosol but will try it next time. And it's free.
