went to halfords and got a headlight bulb ...472-h4...12 v..60/50 w
sussed out eventually how to take it out and replace but now the light is nowhere near as bright as the other one..which was the same bulb.....any ideas?
dim headlight bulb ...brand new
- Apprentice Bongonaut
- mikeWalsall
Re: dim headlight bulb ...brand new
Usually a bad bulb holder or earth connection ..
Some people change the dodgy plastic connection with a ceramic one .. cheaply / easy to source from eBay ..
thank you very much Mike....I have wiggled the connector and the light goes bright...wiggle it again and its dim...a bit like me I suppose
Its a common fault
This is an excellent idea unless the holder has already started to melt or degrade.
http://www.ebay.co.uk/itm/2X-H4-PLUG-IN ... XQxU9SBipc
I often just cut them off and fit a new one but I always add an additional Earth cable, Land Rover Discovery's are notorious for it
