Heaters blowing cold on most temperature settings
jimmo62
Post by jimmo62 » Sun Sep 27, 2015 5:09 pm
I have the automatic aircon/heating version (2.5 diesel 1995) and it seems to blow cold air on all temperature settings except 31C (blows hot air), 30.5C (blows warm air), 30C (blows slightly warm air) - all other settings it blows either ambient temp air (i.e. air from the outside) or cooled air.
Is that right -I was expecting it to maintain the chosen temp by blowing warm air on other settings as well.
I have cleaned out the little fan thingy in the dash by the glovebox, any ideas what I should try next to investigate further, or do I just need to get the instructions on how to use the controls....!
Re: Heaters blowing cold on most temperature settings
Post by g8dhe » Sun Sep 27, 2015 5:24 pm
Check the servo, link wire and control vane rod down in the passenger footwell, the servo controls the position of the vane inside the air mixing box its part G3-10 on the wiring diagram below;
and its located here;
and a photo of the parts;
jimmo62
Post by jimmo62 » Sun Sep 27, 2015 5:28 pm
Excellent, thanks. I will look tomorrow.
Diplomat
Post by Diplomat » Sun Sep 27, 2015 6:20 pm
I never knew that any were fitted with that style of heater way back in 1995.
Learn something every day on here!
Frank
They flew, I took up naturism
