Power steering Top pinion oil seal... at last
mikexgough
Post by mikexgough » Wed Sep 09, 2015 12:57 pm
I have now found a supplier of the Top Pinion Oil Seal..... it seems Corteco and Nok are very difficult to source these days, so I have found a supplier for the usual power steering seal failure............ in Slovakia.
These people are Power Steering specialists and will sell seals for many cars and vans as well as recon racks.
Anyway I have a supply and yes they are a reasonable price too, so you don't have to get a full rack kit unless you want to of course.
Re: Power steering Top pinion oil seal... at last
Post by mikeonb4c » Wed Sep 09, 2015 3:04 pm
mikexgough wrote:I have now found a supplier of the Top Pinion Oil Seal..... it seems Corteco and Nok are very difficult to source these days, so I have found a supplier for the usual power steering seal failure............ in Slovakia.
Yayyy, really useful stuff to know Mike and thanks. Don't we have some kind of sticky thread / place where we can put info on replacement/alternative parts etc? If so maybe the mods could move it / copy it to there?
Post by teenmal » Wed Sep 09, 2015 5:53 pm
Can you tell us the price inc p&p.
Gasy
Post by Gasy » Wed Sep 09, 2015 6:11 pm
These old busses will live on like the vdubs but better
Tony x
Post by Tony x » Wed Sep 09, 2015 7:15 pm
Gasy wrote:These old busses will live on like the vdubs but better
Yes - I've often thought so.
And look what they sell for...
Post by Northern Bongolow » Wed Sep 09, 2015 7:54 pm
thats good news mike well done, i know how hard it is to source these as i put my very good chap onto it a few years ago and he failed.
=D> =D> =D> =D> =D> =D> =D> =D> =D> =D> =D> =D> =D> =D> =D> =D> =D> =D> =D> =D>
mikexgough
Post by mikexgough » Sun Sep 13, 2015 2:17 pm
Sorry been away for a few days..... the seals ...they have to come from Slovakia... work out at £9 each to me... happy to sell on for that cost plus postage... which is of course less than a full rack kit...
The seals are listed for the Bongo/Vito/Ducato and the correct size too... a big thanks to Ingrida on this one
aquatix
Post by aquatix » Thu Jan 07, 2016 7:13 pm
Hi Mike - I desperately need one of these top seals. Have you got any in stock please ? [-o<
Steering rack started leaking a year ago, but needed to stay mobile so opted for the Lucas seal restorer. It took 2 bottles but worked well enough for about 10,000 miles and twice around the Alps.....
Unfortunately it started making a noise again over Christmas and today the power steering totally failed (not nice). On checking the brake fluid it was totally empty, so refilled with the last of the Lucas stuff, only to find it was pi$$ing straight back out all over the drive !!! :evil: Reckon the cold weather finished off the remaining seal.
Started pricing up steering racks - unhappily, due to melted credit cards post-Xmas - and luckily found this thread. Hope you have a spare seal to post out urgently, as it seems daft buying a whole kit (or new rack) when only the top one has failed.
Will PM you with my details. Oh, and if anyone has a link to the best method of actually fitting the seal it would be greatly appreciated ! Thanks
Post by Northern Bongolow » Thu Jan 07, 2016 9:51 pm
mikeWalsall
Post by mikeWalsall » Thu Jan 07, 2016 10:59 pm
I mess around with motor bikes and leaky seals are very common .. and a routine job on 2T cranks ..
I generally use a spring puller (as used to pull springs on M/Bike center stands) to get oil seals out ..
aquatix
Post by aquatix » Fri Jan 08, 2016 1:33 am
Thanks for the tips / link. It looks easy enough bar the skinned knuckles and moderate swearing to actually pull the seal out ...... :lol:
Just need a seal now ....... [-o<
mikeWalsall
Post by mikeWalsall » Fri Jan 08, 2016 11:13 am
Never done a Bongo rack .. but if you buy / borrow / utalise a 'spring' puller similar to mine .. should work fine .. I never have any hassles ..
Keep hook flat to the lip of the seal .. when it's far enough in .. twist hook into position and pull ..
Post by rita » Fri Jan 08, 2016 12:00 pm
aquatix wrote:Thanks for the tips / link. It looks easy enough bar the skinned knuckles and moderate swearing to actually pull the seal out ...... :lol:
Hi , it would (if you intend keeping the vehicle for any length of time)check the bearings for end float and the shaft for wear (grooved).
Good Luck
mikeWalsall
Post by mikeWalsall » Fri Jan 08, 2016 12:35 pm
Good point .. also inner track rods .. and track rod ends are easily sourced from motor factures /eBay etc:..
munroman
Post by munroman » Fri Jan 08, 2016 6:16 pm
I've done this job twice on 2 Bongos, most recently with Mikes seal which worked just fine.
My advice.
Mark how the steering lines up to make refitting easier when refitting the joint to the pinion.
I found the universal circlip pliers useless, proper internal circlip pliers are required.
I used a cordless drill to carefully drill a hole in the seal, then a woodscrew to pull the seal out, this works just fine.
Well done to Mike for sourcing this seal, my MOT man was impressed I had fixed it for so little!
