Replacing Rear Shocks
Rob101
Post by Rob101 » Fri Sep 04, 2015 7:04 pm
Hi All,
One of my rear shocks was leaking, so I've bought a new pair. As there are only a couple of bolts I figured I could DIY. Simple question : I don't own a spring compressor - is it required for the job or can the shock be bolted on without compressing the spring??
Any other tips gratefully received before I attack the van with a spanner!
Rob
scanner
Re: Replacing Rear Shocks
Post by scanner » Fri Sep 04, 2015 7:10 pm
Just put axle stands under the axle and let the weight of the body compress the springs.
I've only ever used compressors for front springs on struts.
wonkanoby
Post by wonkanoby » Fri Sep 04, 2015 7:12 pm
not needed just 2 bolts each
Rob101
Post by Rob101 » Fri Sep 04, 2015 7:18 pm
Thanks guys :-)
I've got a trolley jack and the scissors jack, so between them both should get the alignment right!
Just hope the bolts come off ok :lol:
Post by mikeonb4c » Fri Sep 04, 2015 7:58 pm
Rob101 wrote:Thanks guys :-)
Don't work underneath it without axle stands would be my advice. I've seen a 2 ton trolley jack let go when used on a Bongo, and a scissor jack (if used on the jacking points) won't keep the spring in compression.
Post by Bob » Fri Sep 04, 2015 8:08 pm
Mike's point can't be made to strongly.
Axle stands before you go under. 8)
And on solid ground.
scanner
Post by scanner » Fri Sep 04, 2015 8:11 pm
scanner wrote:Just put axle stands under the axle and let the weight of the body compress the springs.
..... repeated for the avoidance of doubt.
Post by Simon Jones » Fri Sep 04, 2015 10:37 pm
As said, spring compressors not required as the shocks are outside of the springs. I changed mine a while back and it's quite a simple job but you may find getting the lower bolts undone tricky if they've rusted. Lift the rear of the van and prop securely on stands so the axle is hanging and then use a trolley jack to just allow you to jiggle it around to take the weight off the bolt to allow it to be slid out.
Rob101
Post by Rob101 » Wed Sep 09, 2015 9:21 pm
Thanks All - just letting you know I'm alive!
The nuts wouldn't budge, even with copious amounts of WD 40, so off to the mechanic we go!
(he's got a pit).
Rob
Post by mikeonb4c » Wed Sep 09, 2015 9:24 pm
Rob101 wrote:Thanks All - just letting you know I'm alive!
(he's got a pit).
Rob
An all too common frustration to the best laid plans of mice and men, especially on an old Bongo :-(.
