brake pipe renewal
moffatt
brake pipe renewal
Post by moffatt » Fri Jun 26, 2015 9:35 pm
Hi everyone, had to change my mid to rear metal brake pipe and had a hell of a job getting it off ( goes over the top of the fuel tank :evil: )
Is it legal to replace the whole length with a flexible pipe???????
Re: brake pipe renewal
Post by rita » Sat Jun 27, 2015 9:48 am
There is no reason why you can not use PUCKER brake hose, as these vehicles already use them.
The hoses would need to be of the correct length and secured (bracketed), and you could experience some sponginess with the brake pedal as a result of using this type of hose..
Good Luck.
JoeC
Post by JoeC » Sat Jun 27, 2015 10:07 am
Use braided hose and you won't get the spongyness.
Cab-ova pete
Post by Cab-ova pete » Sat Jun 27, 2015 2:18 pm
Hi and welcome moffat :D talking about brake pipes I'm going to lightly rub mine down with fine sanding and then re-grease them, trying to get the whole underside sealed for winter :D hope you get it sorted
Peter
