V6 exhaust gas recirculation.
- Rapidair65
After looking at the parts diagrams, it appears that our 1998 V6 has an EGR system fitted. Is there any benefit from blanking or removing this system and will it affect the MOT emissions test?
1998 green and silver V6 called 'Blossom'
2004 white 2 litre tin top called Buzz.
Re: V6 exhaust gas recirculation.
I've blanked mine off on my diesel
Some say
Better mpg
And power
You'd never notice it
And I'm running a k&n racing air filter
Boy racer
Some say
Better mpg
And power
Boy racer
have a word with alans at plymouth, hes a good chap, he sells the blanking plates for the diesels, he will also advise on the pro and cons of doing the v6.
- Rapidair65
Thanks, I'll drop him an email tomorrow.
- Simon Jones
I think it's a crankcase and petrol vapour recirulation system. The diagram shows no obvious take off point on the manifolds: http://lushprojects.com/bongopartsmk2/c ... mgno=.html
This shows the carbon canister and associated pipework: http://lushprojects.com/bongopartsmk2/c ... 02.html#16
This is the vacuum and cold start/air con solenoids: http://lushprojects.com/bongopartsmk2/c ... f02.html#1
- Rapidair65
Now I look at the parts diagram, you're probably right Simon. Although the parts list does mention exhaust gas recirculation, there doesn't appear to be any connection to the exhaust. It is probably a crankcase breather system.
windywatson
- Tribal Elder
Ye, not the same type of system as the EGR on a diesel engine. Leave well alone, the system is more of a breather system burning off any crank case fumes etc, so I've been lead to believe by my garage when I asked about EGR blanking.
Windy-Watson
2001 V6 Tin Top
2001 V6 Tin Top
- mikeWalsall
Just a regular PCV (Positive Crankcase Ventilation) system found on most petrol engines ..
Just check the one way valve and pipe work is clean that's about it ..
- Rapidair65
Thanks everyone! I was checking all the pipework under the van and couldn't figure out what this sytem was. I can tell you, the Bongo has more pipes than an Airbus engine!
