venting a 12v compressor fridge
the1andonly
Post by the1andonly » Tue May 26, 2015 9:18 pm
I would like to put my 12v compressor fridge in a cupboard/ box.
how much ventilation is required to allow it to function correctly. 1" or 2" gridded hole? low or high?
Re: venting a 12v compressor fridge
Post by g8dhe » Tue May 26, 2015 9:21 pm
Not a lot, our compressor is mounted over the rear air con. unit behind the fridge itself and only has a very small vent panel in the conversion woodwork, but there is also the ventilation behind the plastic trim that has been removed to allow its fitting.
the1andonly
Post by the1andonly » Tue May 26, 2015 10:39 pm
Thanks Geoff
my side panels will be in place and insulated with a wool synthetic mix.
any real venting will be into the van area.
dave_aber
Post by dave_aber » Wed May 27, 2015 6:47 am
I have a Vitrifrigo C42L, with a remote compressor (Danfoss BD35).
I have mounted it inside the main cupboard om my conversion, transverse with the tail end over the wheelarch :
Once the main face of the conversion is in place, the fan draws air from inside the cupboard, and vents it out into the van through a timber vent:
The seat pretty much gets in the way of this vent, but the fridge seems to do OK. If I was doing it again, I'd probably try yo avoid this clash with the seat though!
Image...Image
