indicators and hazards
To keep it short i have neither. When i indicate I get a clicking noise but nothing else and when I press the hazard light button I get nothing at all.I have checked and replaced fuses and also changed flasher rely.Any Ideas.
Re: indicators and hazards
Light problems are usually earth related
Try earthing things out with a new earth supply
But I think I have heard of a faulty hazard switch causing your problem
have you tried changing the bulbs
- Simon Jones
Is there any history to this: did they just all stop at once, or have there been problems for a while? Have you recently had a tow bar fitted, or perhaps hooked up a trailer/caravan/light board for the first time? Do the tell-tale lights on the instrument panel and hazard switch flash and is the clicking at normal speed or very fast? Have you fitted LED bulbs?
I had a small crash and the indicator was pulled out snapping both wires,I got a replacement indicator and connected both wires everything was fine for a while.Then the replacement iindicator would stop working but the rest of the lights worked fine including hazards.I was then removing the indicator and it started to work this happened a couple of times then they all cut out.what I have now is just a clicking noise when I use the indicators and it speeds up when i switch the hazards on. No green aroows on dash.i have tried a replacement flasher rely.
I have led side lights and stop/tail lights but I have had these for a while.
There are two fuses, one drives the relay module the other powers the lights,you have blown the lights fuse!
http://www.g8dhe.net/bwm/
Thanks i will give it a go any idea what fuse it is
Use the link and select "By Fuse Problem" then from the dropdown choose Lights- Turn Hazard it will show you the two fuses.
Thanks for all your help fixed now was fuse no2 it looked ok to the eye but was faulty.
