Hi all
Looking to get one of these setups - .  Coolant alarm seems easy enough - but I'm a bit confused by the temp sensors:
TM2 - basic sensor with alarm set level
TM1 - Newer version of TM2 that can record max temp and can also alarm for low oil pressure
TM4 - Temp sensor with some more messages (e,g, sensor unavailable) but no max temp record.  Can do oil pressure and also control the fan with a £10 relay
Does that seem fair?  What do you really need?
I've got a mason temp alarm (http://www.townace.plus.com/ie/ietemga2.htm) along with a homebrew temp gauge, but one something a bit more adjustable and tidy
Tim
						Hadyn Coolant / Temp Alarms
- Simon Jones
Re: Hadyn Coolant / Temp Alarms
There's a handy factsheet that should answer most of your queries: http://www.igmaynard.co.uk/bongo/member ... Alarms.pdf
I've got one of these temp alarms has outputs for extra fans etc 111052553849
£37
http://www.ebay.co.uk/itm/111052553849? ... EBIDX%3AIT
And one of these low coolant alarms
Had both for. 2 years no problems
Low Coolant Level Alarm 12V £20
( 170927068334 )
Links not working just put numbers into ebay
									£37
( 170927068334 )
Thanks all.
						- haydn callow
Suggest a TM1/low Coolant combi alarm ... Assuming you have a diesel.
http://www.ebay.co.uk/itm/Low-Coolant-L ... 27cc0c14aeGasy wrote:I've got one of these temp alarms has outputs for extra fans etc 111052553849
£37
( 170927068334 )
The price has increased slightly but still very good value .
- Simon Jones
Haydn's LCA has the added benefit of automatic self-test whenever you turn the ignition on.
