water pump on sink
steveandmary
water pump on sink
Post by steveandmary » Tue Mar 10, 2015 7:40 pm
hi water pump in sink , making , continuous noise all the time . and when i use tap it works correctly . i think pump broken . any ideas please , thanks all .
Re: water pump on sink
Post by g8dhe » Tue Mar 10, 2015 8:22 pm
If its whirring ALL the time, then most likely the switch is faulty, and its just letting the water out once its lifted to open the valve.
Gasy
Post by Gasy » Tue Mar 10, 2015 8:39 pm
The switch is more than likely in your tap
And the pump is fine
steveandmary
Post by steveandmary » Tue Mar 10, 2015 8:48 pm
gasy is this fixable or do i need new tap . thanks
Gasy
Post by Gasy » Tue Mar 10, 2015 9:01 pm
You can just buy the micro switch
Take tap down to local caravan shop or have a look on eBay for switch
Take tap out and see what type of micro switch it is
Will be less than £10
steveandmary
Post by steveandmary » Tue Mar 10, 2015 9:08 pm
thanks gasy will take it to caravan shop tomorrow .
Post by Northern Bongolow » Tue Mar 10, 2015 9:08 pm
it may have a pressure switch fitted to the system.
google caravan water pressure switch, or heres a bit on them.
http://www.myidealcaravan.co.uk/pressure%20switch.html.
heres what your looking for.
http://www.leisureshopdirect.com/carava ... witch.aspx
