water pump on sink
steveandmary
- Bongonaut
water pump on sink
hi water pump in sink , making , continuous noise all the time . and when i use tap it works correctly . i think pump broken . any ideas please , thanks all .
Re: water pump on sink
If its whirring ALL the time, then most likely the switch is faulty, and its just letting the water out once its lifted to open the valve.
The switch is more than likely in your tap
And the pump is fine
steveandmary
- Bongonaut
gasy is this fixable or do i need new tap . thanks
You can just buy the micro switch
Take tap down to local caravan shop or have a look on eBay for switch
Take tap out and see what type of micro switch it is
Will be less than £10
steveandmary
- Bongonaut
thanks gasy will take it to caravan shop tomorrow .
it may have a pressure switch fitted to the system.
google caravan water pressure switch, or heres a bit on them.
http://www.myidealcaravan.co.uk/pressure%20switch.html.
heres what your looking for.
http://www.leisureshopdirect.com/carava ... witch.aspx
