Easy way to replace gear strip bulb
jimmo62
Post by jimmo62 » Thu Mar 05, 2015 6:38 pm
The bulb which illuminates the gear indicator strip on the centre console has blown, is there an easy way to get at it to replace it - I don't seem to be able to lift the moulding which holds it out. Do I need to remove the gear selector knob?
Ta
Jimmo
Re: Easy way to replace gear strip bulb
Post by Simon Jones » Thu Mar 05, 2015 7:03 pm
Have you removed the centre console & checked if it's accessible? Ignore the wires towards the bottom of this picture, but you can see 4 that go off under the silver surround. They may be something to do with it. You can also see how the silver part clips over the inner part so I would imagine you would just need to pop that off.
jimmo62
Post by jimmo62 » Thu Mar 05, 2015 7:15 pm
Thanks Simon - I did try unclipping all the clips around the silver piece but it would then move a bit but I could not lift it off.
I followed the wires to the bottom of the bulbholder hoping it would just pull out but no luck.
I will try taking the gearshift knob off next!
Post by Simon Jones » Thu Mar 05, 2015 8:59 pm
I dont think removing the knob will help as its not really anywhere near the bulb. Diagram may help: http://lushprojects.com/bongopartsmk2/c ... mgno=.html
Post by g8dhe » Thu Mar 05, 2015 10:03 pm
jimmo62
Post by jimmo62 » Thu Mar 05, 2015 10:22 pm
Thanks Geoff, that's my job for tomorrow sorted!
cheers
Jimmo
Post by g8dhe » Thu Mar 05, 2015 10:30 pm
Actually looking at my own photo's you don't need to remove the cover itself, from the drivers side simply release the brown holder which should be in the hole where I have run the extra wires I needed;
you should then be able to replace the lamp and re-insert it, twist to lock in place.
