Glowplug vacuum solenoid a
langtoftnick
Post by langtoftnick » Thu Feb 12, 2015 7:40 pm
I think I am right in saying there are 4 vacuum solenoid sat the top of the block on the drivers side? One of these has broken, the pipe has sheared off and I need to get replacement. Anyone ow the part number and where I can get one from please?
Gasy
Re: Glowplug vacuum solenoid a
Post by Gasy » Thu Feb 12, 2015 8:45 pm
Don't now the answer for you
But try a George from bongo spares a breakers on here that loads use
Search on here his number will be on here if someone don't put it up soon for you
Is that langtoft near market deeping
I'm a deeping boy originally
Post by Northern Bongolow » Thu Feb 12, 2015 8:55 pm
put 12 v to it to test it is still working if it is then you could repair it. i use roll pins, put a small one in the hole then a larger one over the top rotated 180 deg so its airtight, then refit the pipe.
http://www.google.co.uk/imgres?imgurl=h ... DIQMygRMBE
or ring george.
http://www.bongospares.co.uk/
Post by Simon Jones » Thu Feb 12, 2015 10:31 pm
I think there are two types of vacuum solenoids as I recall.
langtoftnick
Post by langtoftnick » Fri Feb 13, 2015 9:31 am
Gasy.... yep Langtoft in the heart of the rolling Fenland countryside.
Thanks for your replies. My mechanical neighbour is attempting a "repair" but I've ordered a workshop manual as I think Bodgit&Scarper (the previous owners of my Bongo) have done all sorts of things to the engine. There are broken/disconnected vacuum pipes all over the place and they've fitted an afterglow - probably to get over the cold start problems I'm having. BTW the brakes are OK so can't be too much leakage.
Reluctant to start, smokes like hell, lumpy running for 10-15 seconds - once warmed up and moving runs lovely. Compression OK, (one cylinder about 50psi down), glowplugs all work fine out of the vehicle (one is black, running cold in that cylinder?) and getting 12v to the rail.
Post by mikeonb4c » Fri Feb 13, 2015 11:46 am
langtoftnick wrote:Gasy.... yep Langtoft in the heart of the rolling Fenland countryside.
Hmmm. I just got 4 new glow plugs. Of the 4 removed, the working ones all had soot on them and the duff one was a light colour rather like a spark plug. Engine running fine, mpg excellent and switched off warm after a decent run. Not what I'd have expected but... :roll:
Post by rita » Sun Feb 15, 2015 8:15 pm
Hi langtoftnick, could you tell me what figures you got on the compression test?
