hold light flashing
peanutbutter64
hold light flashing
Post by peanutbutter64 » Sat Jan 17, 2015 1:33 pm
can anyone tell me what a flashing hold light means? , it is not picking the right gear when in drive, its an automatic, v6 petrol
Re: hold light flashing
Post by Bob » Sat Jan 17, 2015 1:37 pm
Possibly a sign the alternator is in its way out. :(
mikeWalsall
Post by mikeWalsall » Sat Jan 17, 2015 2:07 pm
As you have already observed it indicates a gearbox fault ..
Gasy
Post by Gasy » Sat Jan 17, 2015 2:40 pm
check gearbox oil level to start with
The diesel have to be done with engine running
Move gears back and forth a few times
Then check level with engine running and in park
Post by g8dhe » Sat Jan 17, 2015 9:31 pm
The flashing Hold light means that the transmission computer is reporting a fault, see the fact sheets for error codes.
