Recirculate lever jammed
garethjr
Post by garethjr » Tue Jan 13, 2015 10:14 pm
Hello all,
I have just noticed that our recirculate / outside air lever is jammed in the recirculate position. I don't think this has been moved since we got our Bongo in September, but we probably didn't notice then because we had the windows open!
I don't want to try to force it across and break it -has this happened to anyone else? How did you resolve it?
It's making life difficult because we are recirculating the same moist air all the time, so the windscreen takes ages to clear even with the aircon on.
Thanks,
Gareth :D
Gareth
1999 2.5V6 AFT
Re: Recirculate lever jammed
Post by Bob » Tue Jan 13, 2015 11:14 pm
Can't say I've had this problem, but the glove box comes out really easily.
Just open it and press the two sides together, it drops further and lifts way, you may be able to reach in and have a firkle behind the control.
However, I'm not going out in this weather to check. :wink:
the1andonly
Post by the1andonly » Tue Jan 13, 2015 11:21 pm
manual controls?
do they move without changing direction, or are the levers jammed
read
http://igmaynard.co.uk/bongo/forum/view ... =3&t=68327
the last photo is behind the gray panel in the drivers foot well.
the rod can pop out (the little restraining bit of plaky has broken on mine and has popped out frequently.
garethjr
Post by garethjr » Tue Jan 13, 2015 11:38 pm
You're right about the weather, it was snowing here earlier!
Yes it's manual, the lever doesn't move at all. I'll have a look from the glovebox end and in the driver's footwell on Saturday to see what's in there.
Thank you both,
Gareth
Gareth
1999 2.5V6 AFT
Post by Bob » Tue Jan 13, 2015 11:42 pm
Let's hope for an easy/cheap fix. :)
novocaine
Post by novocaine » Wed Jan 14, 2015 8:43 am
open bonnet, remove air intake (big thing across middle of engine bay), push flap back. it will be stuck on it's seal.
now go wiggle the knob to get it all moving again.
refit is reverse of removal. :D
oh and hello from a newbie to the site, not a newbie to the world of bongo's, cars and broken down old tat.
Post by mikeonb4c » Wed Jan 14, 2015 9:14 am
novocaine wrote:open bonnet, remove air intake (big thing across middle of engine bay), push flap back. it will be stuck on it's seal.
Welcome, and what a great opening post. =D>
Post by Bob » Wed Jan 14, 2015 9:16 am
Welcome, agree with Mike, thanks. :D
Post by Simon Jones » Wed Jan 14, 2015 10:36 pm
That sounds like the winter / summer flap fitted to some models which just diverts some of the incoming air away from the cabin intake. As I read the original post, it's the recirulation lever on the manual climate control panel on the dashboard. That's more likely to be a mechanical linkage failure on the side of the heater box.
Welcome to the forum. It's a wealth of useful (and useless) info :).
novocaine
Post by novocaine » Thu Jan 15, 2015 9:03 am
nope, that flap is lower down. and controlled by a lever on the side of the airbox if the vehicle is fitted with it, not all are.
the flap that the lever attaches to closes the intake off so it draws back from the cabin, it is right at the top of the airbox.
yes it might be that the push wire is gummed up. it may need lubrication, but you aren't going to move a stiff wire with the tiny little knob.
the linkage on the side of the airbox is fairly simple, not much to go wrong there, but that should be apparent if the flap doesn't move when pushed.
Post by Simon Jones » Thu Jan 15, 2015 9:47 am
Post by mikeonb4c » Thu Jan 15, 2015 10:17 am
novocaine wrote:nope, that flap is lower down. and controlled by a lever on the side of the airbox if the vehicle is fitted with it, not all are.
I'm impressed by your knowledge and unflappability - must be the novocaine =D> :lol: 8)
garethjr
Post by garethjr » Fri Jan 16, 2015 2:06 pm
Thank you all, I'll have a look tomorrow, it wouldn't have occurred to me that it would be jammed under the bonnet, but then I'm used to cars where you can't get at anything under the bonnet and need a mechanic for everything!
It never ceases to amaze me how many people on the forum are willing to help.
:D
Gareth
1999 2.5V6 AFT
Post by mikeonb4c » Fri Jan 16, 2015 8:57 pm
garethjr wrote:Thank you all, I'll have a look tomorrow, it wouldn't have occurred to me that it would be jammed under the bonnet, but then I'm used to cars where you can't get at anything under the bonnet and need a mechanic for everything!
:D
In the summer we Bongo. In the winter we're bored :lol:
the1andonly
Post by the1andonly » Fri Jan 16, 2015 11:41 pm
I'm confused!
not surprising this time of night
any pickys of these levers
