Reversing Light and Beeper not working
Hi Guys
Just had my auto box replaced and have found that the reversing beeper and reversing lights no longer work. I would think that we should be looking at one the cables/sockets on the new gearbox for the switch but what one should we be looking at. Anyone with any photos of the switch cable or with details of where on the gearbox to find it??
Graeme
Graeme
Re: Reversing Light and Beeper not working
best im aware the swith bit is on the gear lever
remove the consul and check its not been unplugged
Is it possible to disconnect the reversing beeper? I'm planning to install reversing warning sensors and I don't want a symphony of beeps every time I back up.
Yes but your reversing sensors will only beep once your close to something
You don't want to forget your in reverse
I like my beeps
Do a search on here for which wire to cut / plug to disconnect
Use and inbetween words
I like my beeps
- Simon Jones
Pretty sure the switch will be in/on the gearbox. It could be the switch is faulty, not connected or needs adjustment. Can't provide any further details I'm afraid.
- mikeWalsall
I would have thought ... 091317640 17640 SWITCH,BACK UP LAMP MT
- Simon Jones
Yes, the other one is the inhibitor switch.
They have an auto box not a manual (mt) box.
