Dashboard illumination , cant read petrol gauge at night!
agentdagnamit
- Bongonaut
I think I must have lost the right hand light in the dash, I can no longer see the petrol gauge when driving at night.
Presumably it is easy to removing the dashboard surround and replace the bulb?
- mikeWalsall
Re: Dashboard illumination , cant read petrol gauge at night
Yes .. Drop down the steering wheel .. remove the self tapping screws around the bezel ..
... remove the four retaining screws ..
... pull the clocks forward ..
.. pull out the electric plugs out from top / back of the clocks ..
[/UR]
.. twist the holder out of the printed circuit ..
[URL=http://s118.photobucket.com/user/bridle ... 3.jpg.html]
.. pull the glass bulb(s) out of the plastic holder .. replace ..
Note .. the large holders are for the dash lights .. the smaller for warning lights .. there are two different coulered small bub holders denoting two different bulb wattage (brightens) ..
[/UR] .. twist the holder out of the printed circuit ..
Excellent! Is it ok if I turn this in to a member's factsheet?
- mikeWalsall
If you mean my pictures Ian then yes it's fine .. I only put them up just as guide to what to find for the original poster ..
Suggest you add the bulb types and numbers as well in the factsheet Ian!
agentdagnamit
- Bongonaut
Thanks Ian, that's amazing (and even looks like I could managed it!).
Yes, the bulb types would help too, sorry about that. I googled quickly but couldnt find what I needed. guess it'll be printed on the blown bulb though.
Stu
Stu
- mikeWalsall
The most common name for the bigger panel bulb is a wedge / 501 / side light / panel bulb ..
Any car shop will sell them ..
agentdagnamit
- Bongonaut
