Passenger Window Stopped Working
Mark Elvin
Post by Mark Elvin » Tue Oct 21, 2014 7:57 am
OK, the passenger window has been refusing to go work recently from either drivers or passenger switch, so I replaced the loom in the passenger door, but it still doesn't work.
It powers up & down if I connect 12v direct to it, there is no power getting to the window switch on the passenger side.
Any pointers as to other likely areas to check.
wonkanoby
Re: Passenger Window Stopped Working
Post by wonkanoby » Tue Oct 21, 2014 9:27 am
check drivers loom as toggle under switches effects it from there
dom_e
Post by dom_e » Wed Oct 22, 2014 12:54 pm
I presume you've checked the rocker switch on the driver side door switch panel hasn't been accidentally turned on? This is an override that prevents the passenger side window opening.
Beyond A to B
BongoBongo123
Post by BongoBongo123 » Sat Oct 25, 2014 4:55 pm
Nice one dom_e ! That had me stumped and explains why it was intermittently working.
They call me light foot.
mikeWalsall
Post by mikeWalsall » Sat Oct 25, 2014 5:46 pm
Some who have had there Bongo for some time miss some of it's little querks ..
One who did not know they had folding mirrors .. other who do not know they can turn the digital rear heating fan on from the front .. others who do not realise if you push the wiper lever forward .. you have a one swipe windscreen wipe .. others who mask the sun sensor for the A/C on the top right hand dash board .. do not realise that there is a little fan in the cabins A/C sensor that can get gobbed up with dust (or dog hairs) .. that the jack handle is clipped to the roof of the storage compartment ..
dom_e
Post by dom_e » Sat Oct 25, 2014 5:50 pm
I like the easy fixes! Glad to have helped!
Beyond A to B
khisanth
Post by khisanth » Mon Oct 27, 2014 9:38 pm
i have a similar problem except it works from the passenger side not the drivers side anyone got any ideas why
Post by Bob » Mon Oct 27, 2014 9:57 pm
I'd start where the loom goes into the driver's door.
Post by g8dhe » Mon Oct 27, 2014 11:12 pm
If it works from the passenger side, then suspect the drivers switch is faulty.
Mark Elvin
Post by Mark Elvin » Tue Oct 28, 2014 7:14 am
New driver door loom has arrived, si I'll hopefully get on to that....eventually!
