Hi folks,
Am looking for a bit of advice on what width of rims will fill the arches but not scuff them.
I have like the standard 15" alloys on it, but the tyre walls are cracking so looking at a full set of wheels and tyres say in the £500 to £600 region.
Any advice would be great would 8j be to big maybe?
Cheers Charlie
Wheel widths
Moderator: Ian
Re: Wheel widths
I don't know your answer, but consider the wheel offset as well (ET). A smaller (or more negative) offset will make the wheel stick out more and will be more likely to scuff the arch.
There is a topic/article on here somewhere about larger diameter wheels/tyres, that might have the answer (I've not read it, so can't comment).
I believe the standard wheel size is 6x15 ET40, bore size: 67.1
(Source: http://www.wheel-size.com/size/mazda/bongo)
Apparently, wheels from these cars fit too ...
http://whichwheelsfit.com/index.php/sel ... a-bongo-95
There's always a 'bigger picture'
Re: Wheel widths
Try wheel quick in Wigan
Hes a top bloke and will deliver
http://www.wheelquick.co.uk/
Hes a Bongo specialist too
Re: Wheel widths
Why not get RX8 wheels and do the 235 45 18 tyres.
four decent tyres and a set of RX8 18" would be cheaper.
