fuel gauge - followed worksheet - always showing fuel level
Frediculous
Post by Frediculous » Mon Sep 22, 2014 2:00 pm
So, along with almost every other Bongo owner it seems, I have an issue with the fuel gauge!
I've gone through the worksheet and tried some of the quick fixes. I first tried to earth the tank from underneath - but this didn't have any effect so I thought I'd lift the carpets and try and earth it from inside.
The fuel gauge now shows a level of fuel (not sure if its the right level....) but it constantly shows it even with the key out of the ignition - is this normal?
I'm slightly sceptical of what I've done because the first fix didn't work......
Colin H F
Re: fuel gauge - followed worksheet - always showing fuel le
Post by Colin H F » Mon Sep 22, 2014 2:03 pm
yes mine showed the petrol level even when switched off
Post by Bob » Mon Sep 22, 2014 2:56 pm
Normal. 8)
Colin H F
Post by Colin H F » Mon Sep 22, 2014 3:20 pm
there you go =D>
Frediculous
Post by Frediculous » Mon Sep 22, 2014 8:26 pm
Thanks all.
Between the help that you guys offer and the fact sheets I'll have her up to scratch in no time (well maybe a bit of time....)
Post by Bob » Mon Sep 22, 2014 10:01 pm
Keep at it, Butt
Bongy is always worth it. :D
