mystery black box
JamesO
mystery black box
Post by JamesO » Sun Aug 31, 2014 7:30 pm
I have a black box under my steering wheel. It seems to have 8 switches and 4 knobs and an on/off. Any ideas what it is for and what the settings are?
Thanks.
J.
Re: mystery black box
Post by Bob » Sun Aug 31, 2014 8:04 pm
I'm guessing it's a Turbo Timer, of which a search will reveal all.
Only my best guess though. :wink:
Or a bit of audio kit, welcome aboard. :D
TheStinkyHippy
Post by TheStinkyHippy » Mon Sep 01, 2014 9:48 am
Using google translate and taking photos of my screen....
At the top above the knobs,
Number one has above it: Fine shock 1,
Then: Fine shock 2,
Then: High impact
Then: Current
Above the bank of 1,2,3,4,5,6,7,8 is written: Configuration switch
One the white panel, the words across the top are the same: Configuration switch
In black on the left: The word may be: Settings
No:1, translates to : (maybe) Fine shock alarm
No:2 translates to: High impact alarm
No:3: Thunder flow processor (maybe)
No:4 Repel alarm time
No:7 IG Exercise
Hopefully that is enough for someone to understand what this device is.
Unfortunately none of the A/B icons seem to translate
Dodgey
Post by Dodgey » Mon Sep 01, 2014 10:47 am
It's part of a car alarm, I'd assume - with shock settings...
Post by teenmal » Mon Sep 01, 2014 1:00 pm
Its a Prototype alarm system for Fort Knox.
helen&tony
Post by helen&tony » Mon Sep 01, 2014 1:36 pm
I think Teenmal may be wrong...It is probably a Black Box, and is useful in the event of a disaster....pilot recording available, and sensors for mid-air collision, passenger disturbance, attack or engine falling off
Seriously, It's an alarm add-on for 2-stage shock sensing...programmable by the look of it!...
JamesO
Post by JamesO » Tue Sep 02, 2014 10:07 am
Thanks guys.
I have now asked a friend of a friend to translate it and it does seem that it might be some sort of electric shock alarm system! Holy Cow! Now my question is, what should I do about it?
Has anyone on here seen anything like this before? I have had the bongo for nearly a year now and I am pretty sure it has not shocked anyone or anything yet!
J.
mikeWalsall
Post by mikeWalsall » Tue Sep 02, 2014 12:19 pm
I think by shock they meen a movement alarm .. or if someone breaks a window ..
Some are quite sensative (and annoying) in that a passing vehicle can cause your motor to 'shake' and trigger the alarm .. they usualy need careful setting up ..
roosmith
Post by roosmith » Tue Sep 02, 2014 12:29 pm
Unless in Japan you are allowed to hurt the little urchins? That would be much better! I'm in the security industry and constantly laugh at what you're not allowed to do to the intruder (e.g. damage his hearing with a loud alarm!)
mikeWalsall
Post by mikeWalsall » Tue Sep 02, 2014 1:32 pm
Or break there legs with a baseball bat ..!!
roosmith
Post by roosmith » Tue Sep 02, 2014 1:45 pm
Indeed, or other such reasonable measures!
philpdr
Post by philpdr » Tue Sep 02, 2014 5:30 pm
roosmith wrote:Indeed, or other such reasonable measures!
:lol: :lol:
