Clicking Noise from Behind Dashboard
Weeduggy
Post by Weeduggy » Thu Aug 21, 2014 6:48 pm
As it says in the title, I have a clicking noise coming from behind the dash board, Sounds like a relay clicking. If i touch the dashboard around the rear windscreen switch i can feel it clicking. Its a pretty rhythmic noise that starts just after you set off and seems to keep going. It did stop a couple of times but now just goes on and on. Everything appears to be working.
Anyone have any ideas.
Re: Clicking Noise from Behind Dashboard
Post by Simon Jones » Thu Aug 21, 2014 7:00 pm
There's a small fan behind the little vent on the dashboard that draws air past a thermistor that controls the temperature of the climate control. Perhaps it's that? What sort of rate is it clicking at?
Weeduggy
Post by Weeduggy » Thu Aug 21, 2014 7:04 pm
Every 3 seconds or so. Continously, no fluctuations.
karena
Post by karena » Thu Aug 21, 2014 8:04 pm
this is going to sound really stupid but i had a rhythmic clicking when i first got mine that seemed to be coming from behind the dashboard -turned out to be my key fob. -just a thought :oops:
Post by Northern Bongolow » Thu Aug 21, 2014 8:30 pm
press the odometer reset button to zero the miles/kms, it may be that, they get knocked when you do the dusting.
chipvan
Post by chipvan » Thu Aug 21, 2014 10:20 pm
got a leisure battery charge kit?
philpdr
Post by philpdr » Thu Aug 21, 2014 11:36 pm
karena wrote:this is going to sound really stupid but i had a rhythmic clicking when i first got mine that seemed to be coming from behind the dashboard -turned out to be my key fob. -just a thought :oops:
:lol: :lol:
Weeduggy
Post by Weeduggy » Fri Aug 22, 2014 8:29 am
No leisure Battery but I'm sure i reset the trip clock prior to this starting so it may well be that. I'll reset again today and see what happens.
Post by mikeonb4c » Fri Aug 22, 2014 8:48 am
I dunno - you girlies :lol: 8) xxx
Post by rita » Fri Aug 22, 2014 9:21 am
Weeduggy wrote:No leisure Battery but I'm sure i reset the trip clock prior to this starting so it may well be that. I'll reset again today and see what happens.
Yes this is quite a common fault when you reset the trip, the transfer mech can get jammed and cause a clicking sound as the wheels (speedo) try to turn..
Post by Simon Jones » Fri Aug 22, 2014 12:54 pm
The other clues will be that it only happens when driving & the frequency of clicking will increase with speed. If the main odometer gets stuck that may be a sign that the reading has been 'corrected' in the past.
Weeduggy
Post by Weeduggy » Fri Aug 22, 2014 8:18 pm
Well it was the trip clock. Had a look at it today and having driven at least 100 miles previous to this it was sat at 0. Must have stuck when i reset it. Reset it again and all is well.
Actually feel a bit daft now but you live and learn.
philpdr
Post by philpdr » Fri Aug 22, 2014 8:48 pm
Weeduggy wrote:Well it was the trip clock. Had a look at it today and having driven at least 100 miles previous to this it was sat at 0. Must have stuck when i reset it. Reset it again and all is well.
No need to feel daft,others,myself included have learned something from the answers to your post. :)
Post by Bob » Fri Aug 22, 2014 9:59 pm
Exactly, worth posting so we all learn.
Thanks.
JoeC
Post by JoeC » Sat Aug 23, 2014 10:53 am
Bob wrote:Exactly, worth posting so we all learn.
Here, here.
