AFT Question..
The Reverend
AFT Question..
Post by The Reverend » Thu Aug 07, 2014 3:33 pm
The AFT has decided to stop working... the microswitch on the handbrakes is fine, but there is no warning beeping at all.. any ideas? Fuse perhaps? Thanks in advance!
Re: AFT Question..
Post by Doone » Thu Aug 07, 2014 3:52 pm
The fuse to check is under the steering wheel, it's a 30amp fuse, 2nd row down, fourth one in.
Re: AFT Question..
Post by g8dhe » Thu Aug 07, 2014 4:02 pm
Also there are two fuses the 15 Amp as well;
Image Image
The Reverend
Re: AFT Question..
Post by The Reverend » Thu Aug 07, 2014 5:33 pm
..alas. not those fuses. Just changed them and no difference. Stumped.
Re: AFT Question..
Post by Simon Jones » Thu Aug 07, 2014 7:24 pm
Tried following suggestions in the factsheet? http://www.igmaynard.co.uk/bongo/member ... ts/aft.pdf
Re: AFT Question..
Post by g8dhe » Thu Aug 07, 2014 8:10 pm
So does the Handbrake light on the dashboard light ?
When you press the Raise button -no beeping - but is there any noise at all ?
The Reverend
Re: AFT Question..
Post by The Reverend » Thu Aug 07, 2014 11:38 pm
Handbrake light on, and quiet as the grave..no beeps, no signs of life at all.. :(
al & chris
Re: AFT Question..
Post by al & chris » Fri Aug 08, 2014 12:45 am
You are in park on gear change. Not sure if that does make a difference.!
Re: AFT Question..
Post by g8dhe » Fri Aug 08, 2014 10:27 am
Nope there is a signal to the ECU from the AFT which puts it into limp mode if the AFT is up, but certainly prior to 2000 there is no signal to the AFT from the gear stick at all.
Re: AFT Question..
Post by g8dhe » Fri Aug 08, 2014 10:30 am
If you can get to the module, offside rear pillar, would be worth checking connections and making sure there is power to the module. The other item is check the raise/lower switch and make sure that it is switching the 12 volts to the module;
The Reverend
Re: AFT Question..
Post by The Reverend » Sat Aug 09, 2014 3:00 pm
Thanks for all the ideas, but if it requires electrical knowledge beyond changing a fuse, I think that I'll take it in to someone who knows what they are doing.. Now, who would that be near Harrogate?? ;)
hijimhere
Re: AFT Question..
Post by hijimhere » Sat Aug 09, 2014 5:52 pm
I had a panic until I put my foot on the foot brake - auto in park-handbrake on - ignition on - foot on foot brake -- presto or press switch - aaaahhh the gentle but irritating beep beep -- still not sure I am getting it right or if there is an undetected problem! Yep its ok to laugh - is it worth learning Japanese?
