AFT Question..
- The Reverend
- Apprentice Bongonaut
AFT Question..
The AFT has decided to stop working... the microswitch on the handbrakes is fine, but there is no warning beeping at all.. any ideas? Fuse perhaps? Thanks in advance!
Re: AFT Question..
The fuse to check is under the steering wheel, it's a 30amp fuse, 2nd row down, fourth one in.
Re: AFT Question..
Also there are two fuses the 15 Amp as well;
- The Reverend
Re: AFT Question..
..alas. not those fuses. Just changed them and no difference. Stumped.
Re: AFT Question..
Tried following suggestions in the factsheet? http://www.igmaynard.co.uk/bongo/member ... ts/aft.pdf
Re: AFT Question..
So does the Handbrake light on the dashboard light ?
When you press the Raise button -no beeping - but is there any noise at all ?
- The Reverend
Re: AFT Question..
Handbrake light on, and quiet as the grave..no beeps, no signs of life at all..
al & chris
- Tribal Elder
Re: AFT Question..
You are in park on gear change. Not sure if that does make a difference.!
Re: AFT Question..
Nope there is a signal to the ECU from the AFT which puts it into limp mode if the AFT is up, but certainly prior to 2000 there is no signal to the AFT from the gear stick at all.
Re: AFT Question..
If you can get to the module, offside rear pillar, would be worth checking connections and making sure there is power to the module. The other item is check the raise/lower switch and make sure that it is switching the 12 volts to the module;
- The Reverend
Re: AFT Question..
Thanks for all the ideas, but if it requires electrical knowledge beyond changing a fuse, I think that I'll take it in to someone who knows what they are doing.. Now, who would that be near Harrogate??
Re: AFT Question..
I had a panic until I put my foot on the foot brake - auto in park-handbrake on - ignition on - foot on foot brake -- presto or press switch - aaaahhh the gentle but irritating beep beep -- still not sure I am getting it right or if there is an undetected problem! Yep its ok to laugh - is it worth learning Japanese?
