Washer pump
Washer pump
Hi guys my washers have stopped working but when power put to pumps they work and all fuses seem Ok, which is the actual washer pump fuse, any help or advice would be a great help.
Re: Washer pump
Blocked spray nozzles or water tubing is blocked
Blow it through
Blow it through
Re: Washer pump
There's a fuse fact sheet in member's area
Re: Washer pump
Fuse 13 is rear wipers and wash
Fuse 15 is front wipers and wash
Start top left
In fuse box next to drivers knee
So if your wipers are working it's not your fuses
Start top left
- Simon Jones
Re: Washer pump
Compatible direct replacement pump can be bought for under £10. Plenty of info and examples via the search facility.
Re: Washer pump
Cheers guys, I'll check them out this weekend, thanks
Re: Washer pump
test with a test light to see if there is live at the plug when washers pressed, if yes then it maybe an earth fault, these are found just at the side of the headlights,look for 2-3-4 wires going into a block that is bolted to the front panel, could just need a clean as they are a bit in the weather zone.
