Front Differential Oil Seal
Mark Norton
Post by Mark Norton » Tue Jul 15, 2014 3:48 pm
Hi, The front differential to propshaft oil seal has gone, anyone know a replacement part number?
Many thanks Mark
Re: Front Differential Oil Seal
Post by rita » Tue Jul 15, 2014 5:23 pm
Mark Norton
Post by Mark Norton » Tue Jul 15, 2014 5:28 pm
Many thanks!
Post by Northern Bongolow » Tue Jul 15, 2014 8:14 pm
try cleaning the breather on top of the diff, :wink:
Mark Norton
Post by Mark Norton » Wed Jul 16, 2014 5:34 pm
Thanks for the tip but the breather at the top of the diff is clear. The seal has been wet looking with oil for a year or more, after the last trip the underside of the plastic shrouding was sprayed with a mist of oil, I keep putting off changing the oil seal as when I remove the oil filler plug the level never seems to go down.
Post by rita » Thu Jul 17, 2014 3:50 pm
Might also be worthwhile checking the flange (pinion bearing )for lift.
Mark Norton
Post by Mark Norton » Wed Jul 30, 2014 10:29 am
No luck finding a replacement oil seal, Mazda AVA etc all no reply. A friend has the same problem on his Bongo, been leaking for years, just tops up the diff every now and then.
