Hi, The front differential to propshaft oil seal has gone, anyone know a replacement part number?
Many thanks Mark
Front Differential Oil Seal
- Bongonaut
- Bongonaut
Re: Front Differential Oil Seal
Many thanks!
try cleaning the breather on top of the diff,
- Bongonaut
Thanks for the tip but the breather at the top of the diff is clear. The seal has been wet looking with oil for a year or more, after the last trip the underside of the plastic shrouding was sprayed with a mist of oil, I keep putting off changing the oil seal as when I remove the oil filler plug the level never seems to go down.
Might also be worthwhile checking the flange (pinion bearing )for lift.
- Bongonaut
No luck finding a replacement oil seal, Mazda AVA etc all no reply. A friend has the same problem on his Bongo, been leaking for years, just tops up the diff every now and then.
