Towbars
Andy12
Towbars
Post by Andy12 » Sun Jun 08, 2014 7:57 pm
Hi, i'm thinking of putting a towbar on the Bongo and am wondering if the mounting points are already drilled or is it more technical than this ?, also is it possible to buy the OE electrics and they just plug in or again more complicated than this, many thanks Andy.
Driver+Passengers
Re: Towbars
Post by Driver+Passengers » Sun Jun 08, 2014 8:01 pm
The mounting points have captive threaded nuts, so fitting is relatively easy. Mine also required removing the trim just inside the boot to drill a vertical hole for additional support. The towing point at the rear offside is removed. The electrics need to be wired in to one or other of the rear clusters - mine came with Scotch clips but if you can do a better job, then do so! You'll typically need one wire to feed from the opposite side for the "other" indicator. If you're charging a caravan LB then you may need to run an additional wire from the front. Note that part of the chassis I think is spot-welded only - if you're going to be towing a lot, then some folk have this seam welded. Hope some of this helps - a search on the forum should throw up several more threads.
Image Image
Re: Towbars
Post by g8dhe » Sun Jun 08, 2014 10:03 pm
Do however have a read of this before you choose one of the two types that fit a Bongo;
The choice: http://www.igmaynard.co.uk/bongo/forum/ ... 10#p594910
The problem if you choose the wrong one: http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=34743
daaj
Re: Towbars
Post by daaj » Fri Mar 06, 2015 9:50 pm
I don't feel confident enough to fit a towbar myself, but all the fitters I've contacted so far say they can't / won't fit one. Any ideas where I can get one fitted? - I live in Kent.
Re: Towbars
Post by Simon Jones » Fri Mar 06, 2015 9:56 pm
It's not a tricky job if you are confident with the spanners and don't mind drilling a few big holes in the chassis. Surprised no fitters are interested as a quick google indicates Towsure will do it at your home or workplace: http://www.towsure.com/category/Mazda_Bongo_Towbars
Gasy
Re: Towbars
Post by Gasy » Fri Mar 06, 2015 10:02 pm
Jims tow bars offer a nationwide service, come out to you and fitted the stong tow bar to mine for a good price
ELZE
Re: Towbars
Post by ELZE » Sat Mar 07, 2015 12:12 pm
Anyone prepared to say what a good price is these days for a decent tow bar single electrics
Re: Towbars
Post by teenmal » Sat Mar 07, 2015 12:30 pm
This might help re tow bar DIY, please excuse the heavy breathing.
https://www.youtube.com/watch?v=NiII8Tzo1FY
Gasy
Re: Towbars
Post by Gasy » Sat Mar 07, 2015 4:03 pm
Think I paid less than £200 more than £150
Bad memory me
ELZE
Re: Towbars
Post by ELZE » Sat Mar 07, 2015 4:07 pm
Max £200 is what I thought it might be
Gasy
Re: Towbars
Post by Gasy » Sat Mar 07, 2015 4:12 pm
I know if I bought the tow at and did it my self I was only saving about £50
So let them do it
Lad in a car turned up and was done within the hour
Obviously not the first bongo he had done
Carnt see where cables are run or buzzer etc
Tidy job
And did me a rear number plate for caravan
ELZE
Re: Towbars
Post by ELZE » Sat Mar 07, 2015 4:35 pm
Gasy wrote:I know if I bought the tow at and did it my self I was only saving about £50
So let them do it
Tidy job
RESULT!
