Switch
stpn666
Switch
Post by stpn666 » Mon Jun 02, 2014 11:17 am
Hi All
I have discovered a switch in my roof when raised it says cancel lock can anyone explain what this switch is for?
Steve Wales
Re: Switch
Post by g8dhe » Mon Jun 02, 2014 11:24 am
You need to press this switch to allow the roof to lower! Its a safety device, to make sure you check what's in the roof before lowering it! The roof will also stop half way down and will require the normal raise/lower switch to be released and pressed again to complete lowering again a safety check to make sure that the material is laying correct and that nothing is going to jam the roof when fully lowered.
Re: Switch
Post by g8dhe » Mon Jun 02, 2014 11:53 am
Looks like this is related to your other thread http://www.igmaynard.co.uk/bongo/forum/ ... 04#p627104
The switch you mention in this thread is the Roof Lock Cancel switch, it allows you to unlock the roof to allow lowering it.
If there wasn't this safety feature you could squash a person or equipment inside the roof, just by touching the raise/lower switch ....
Re: Switch
Post by Simon Jones » Mon Jun 02, 2014 8:19 pm
Might be worth investing in an owners manual (around £20) which will explain all the controls for you.
http://www.igmaynard.co.uk/bongo/mercha ... tm#Manuals
stpn666
Re: Switch
Post by stpn666 » Tue Jun 03, 2014 8:28 am
Hi All
Thanks for the info very grateful
Steve
Wales
