Fuel pump timing setup
Coradia63
Post by Coradia63 » Sun Jun 01, 2014 8:30 pm
Hi All,
Does anyone know the fuel injection pump timing setup procedure for the 2.5TD 1995 engine? I have got the dial gauge to go in the pump but cant find anything on which timing marks you go by on the engine is it the crank, camshaft or fuel pump pulleys if you do actually use these? the only info I can find is to set it to 0.95mm - 1.05mm.
Any help appreciated
1995 Ford Freda 2.5 TD 4x4 AFT
jimmo62
Re: Fuel pump timing setup
Post by jimmo62 » Sun Jun 01, 2014 9:08 pm
It's covered in detail in the service manual, looks a bit complicated and they recommend the use of a dial gauge...
Coradia63
Post by Coradia63 » Sun Jun 01, 2014 9:34 pm
I know its in the manual I'm just to tight to pay the £60 - £70 for it :lol: especially as this is the only info I need....
Post by rita » Mon Jun 02, 2014 9:26 am
PM sent.
Coradia63
Post by Coradia63 » Thu Jun 05, 2014 10:21 am
Thanks Rita that info was what I needed will try it later when/if my new pump arrives today.
