Hi All,
Does anyone know the fuel injection pump timing setup procedure for the 2.5TD 1995 engine? I have got the dial gauge to go in the pump but cant find anything on which timing marks you go by on the engine is it the crank, camshaft or fuel pump pulleys if you do actually use these? the only info I can find is to set it to 0.95mm - 1.05mm.
Any help appreciated
Fuel pump timing setup
1995 Ford Freda 2.5 TD 4x4 AFT
Re: Fuel pump timing setup
It's covered in detail in the service manual, looks a bit complicated and they recommend the use of a dial gauge...
I know its in the manual I'm just to tight to pay the £60 - £70 for it
especially as this is the only info I need....
PM sent.
Thanks Rita that info was what I needed will try it later when/if my new pump arrives today.
