Just wondering if anyone can guide me in how to remove the front heater fan on a 1996 diesel Bongo. The fan spins by hand but will not switch on. ( brushes?).
The resistor appears to be ok.
Is it easier to remove from underneath?
Front heater fan not running
Re: Front heater fan not running
you do it from above
there is a faq if your a member
its a few bolts and screws and a couple of electrical connectors,one in passenger footwell
- helen&tony
As Wonkanoby says...if you are a member, there's a guide available...It's in the "Fact Sheets" under "Heater Fan Repair"....easy job...15 minutes or so to get the fan out
is it off at all speeds, or does it work on some.
if the fuse is ok then check the lecky plug, this gets a bit of weather abuse, its just in front of the heater fan unit just behind the rad. pull the plug apart and see if its a nice green colour.
