Tailgate spoiler brake light
Jabba's Wheels
Post by Jabba's Wheels » Wed Apr 23, 2014 5:14 pm
Hi, I recently acquired and fitted a tailgate spoiler to my 2000 reg Bongo from a breakers. The spoiler was very grubby and cleaned up almost like new. Fitted it and it looks good - then discovered the spoiler brake light doesn't work. Took out the light fitting and it appears to be a strip of LEDs encased in red plastic with a couple of wires (I assume live and earth) . Connected a meter across the wires and there is a break in the circuit somewhere. :(
Anyone know if the LED units are serviceable (doesn't seem to come apart) :shock: or where I can get a new replacement from? (They aren't in the shop) :?:
Re: Tailgate spoiler brake light
Post by Northern Bongolow » Wed Apr 23, 2014 8:46 pm
Jabba's Wheels
Post by Jabba's Wheels » Wed Apr 23, 2014 8:58 pm
Thanks for that, must've keyed some rubbish into the search engine. (I only got part of the thread). Looks like the 626/eBay option is the way to go. =D>
Post by Northern Bongolow » Wed Apr 23, 2014 9:03 pm
if your searching for several words-------brake light,put and between each word, it finds results better. 8)
Post by g8dhe » Wed Apr 23, 2014 9:06 pm
If you used a normal multimeter then it will not show any resistance reading. Try connecting to a 12volt supply and check that it works that way.
Jabba's Wheels
Post by Jabba's Wheels » Wed Apr 23, 2014 9:16 pm
Thanks Geoff, didn't realise that it won't show any resistance. I had connected to a 12v supply first and checked that all the electrical connections were ok. The whole unit was dead - that came as a surprise! Having said that, it looked like the spoiler had spent a lot of time in serious dampness - had to use rubbing compound to get the cr*p off.
Looked well when I'd finished apart from the dead LED. :)
Shame there doesn't seem to be much 626 spoiler stuff on eBay :(
Post by Simon Jones » Wed Apr 23, 2014 11:36 pm
Have you tried connecting 12v the other way round? LEDs are normally polarity sensitive so will only work one way round.
Post by rita » Thu Apr 24, 2014 8:46 am
You might be able to rustle up something from this lot...
http://www.ebay.co.uk/sch/i.html?_trksi ... &_from=R40
Jabba's Wheels
Post by Jabba's Wheels » Thu Apr 24, 2014 9:54 pm
Thanks Simon, yep - I'd seen the polarity mentioned on various forums. Sadly mine remains unresponsive.
Thanks Rita - I'll keep on looking :)
